interesting jfet...
J
John Larkin
https://www.ti.com/lit/ds/symlink/jfe2140.pdf
Even more interesting if you put the two fets in parallel.
Am 02.06.23 um 19:34 schrieb John Larkin:
I prefer On Semi CPH3910. I paralleled 16 of them.
More bang (less voltage noise) per buck.
< https://www.flickr.com/photos/137684711@N07/52420371063/in/datetaken/
https://www.diyaudio.com/community/threads/ultra-low-noise-jfets-from-texas-instruments.375079/page-12#post-7364203
Gerhard
Those are mainly for the numerous differential amplifier applications for JFETs.
Encouraging that they’re bringing it out in 2023. The matching is very
good, and the 1/f corner is excellent.
Wiring them in parallel basically gets you a $3 CPH3910, only slower.
I’m not sure that I believe 1 nV noise with only 10 mS gM
Cheers
Phil Hobbs
Dr Philip C D Hobbs Principal Consultant ElectroOptical Innovations LLC /
Hobbs ElectroOptics Optics, Electro-optics, Photonics, Analog Electronics
Cheers
Phil Hobbs
It might be interesting to run a couple of packages in parallel, to get
lower noise while keeping the good matching. That would avoid having to
use op amp bandaids on discrete pairs to get decent DC performance, which
we have to do sometimes.
What does it mean for a product to be a \"Burr-Brown\" at this point? It\'s
unclear to me from the document if this is an actual new product, or a
re-released old product, or if \"Burr Brown\" is just like a trim-line
marketing moniker at this point, like buying a Chrysler New Yorker with
the \"Mark Cross package.\"
TI acquired b-b in 2000. Some parts are still considered to be in the
b-b division, but I don\'t know if that has a physical meaning. It may
just be a trademark now, mostly for audio parts.
I asked TI for support on a different part, and the guy said \"That\'s a
Burr-Brown part, we don\'t know much about it.\"
On Fri, 2 Jun 2023 23:09:18 -0000 (UTC), Phil Hobbs
Cheers
Phil Hobbs
Yes, diff pairs in parallel would be good too, if you really need
diff.
I like the clamp diodes; I might use it just for them.
There\'s probably some dumb CMOS part that accidentally has pA or fA
clamp diodes. I\'ve used a DG408 analog mux just as an 8-channel rail
clamp.
I’m not sure that I believe 1 nV noise with only 10 mS gM.
diff.
Not much point otherwise, unless the somewhat-better 1/f corner is a big
deal in a given application. CPH3910s are quieter in the flatband, at
1/10 the price.
The low noise at indifferent gM is interesting, though. An ideal BJT’s
noise temperature is Tj/2, compared to 2/3 Tj for an ideal JFET.
An ideal BJT at 0.25 mA Ic has a gM near 10 mS, so its-Hz voltage noise is
ideally
sqrt(0.5 * 4kT/gM), about 0.9 nV.
An ideal JFET with the same gM has sqrt(1.5)
times more, about 1.1 nV, which is close to what TI claims.
However, that doesn’t leave much space for the resistance of the silicon
and wiring. So using a few packages in parallel makes some sense.
clamp.
It sounds as though they pulled something out of the BB files and
re-implemented it on a modern process with good JFETs.
Pretty cool, in 2023.
Cheers
Phil Hobbs
Dr Philip C D Hobbs
ElectroOptical Innovations LLC / Hobbs ElectroOptics
Briarcliff Manor NY 10510
http://electrooptical.net
http://hobbs-eo.com
On a sunny day (Fri, 02 Jun 2023 10:34:58 -0700) it happened John Larkin
<jlarkin@highlandSNIPMEtechnology.com> wrote in
<5u9k7ih15isssggnooi5rjqp246snh9lek@4ax.com>:
It seems a bit strange to me
In cases where I wanted to use a JFET I would _not_ like diodes on the gate
(extra capacitance, C variable with voltage too), and most certainly not a reverse diode capacitance
path from the supply line to the gate.
OK it seems to be for the audiophile market (XLR connector and < 100kHz link)
I used JFETS at much higher frequency.
As to the many dB signal to noise for audio, some hysteria
who seriously has a place to listen to music or whatever that is silent enough!
Nowhere here, and not in nature either.
In fact for some transmissions I did in the long ago past use a compander
so you could actually hear people speaking softly at the receiver end, or the not so load parts of music.
So maybe the audiophiles club will like it. They have $$$$ to sacrifice...
For me it a big joke that chip.
On Sun, 04 Jun 2023 09:20:24 GMT, Jan Panteltje <alien@comet.invalid>
This is too good a part for audio.
As the front end of a super-quiet amp, the protective diodes are
handy.
On a sunny day (Sun, 04 Jun 2023 03:26:04 -0700) it happened John Larkin
<8hpo7il7l80du1r4c2i4tja5v1580dektj@4ax.com>:
handy.
Any spike on the supply will feed to the input via the capacitance of the protection diode on the supply side.
For RF you do _not_ want varicaps (that is what they do if input bias changes) on the input.
You could argue that if voltage goes up one diode gets less capacitance and the other more.... and vice versa,
would have to measure it.
Maybe someone knows how much thermal? noise those diodes create when receiving alien signals...
Made some nice RF frontend with a JFET cascode long ago.
JFETs make nice LC and xtal oscillators too.
circuit examples:
https://www.ti.com/lit/an/snoa620/snoa620.pdf
