Masz ktoś może mi pomóc w analizie wyjście błędów? Pomóż mi!
D
Dwa
Dostaję błąd podczas instalacji pobrać źródła ..
Ouput jest następujący: --
ann (at) anndesktop: ~ $
cd / home / ann / Desktop /
ann (at) anndesktop: ~ /
Desktop $ ls
bttv0.9.15
epson31411eu.zip motion3.2.9.
tar.gz
bttv0.9.15.
tar.tar epson31411eu.zip_FILES
Desktop $ tar xvzf
/ home/ann/desktop/motion3.2.9.
tar.gz
motion3.2.9 /
motion3.2.9 /
motion.spec.in
motion3.2.9 /
picture.h
motion3.2.9 /
rotate.h
motion3.2.9 /
pwcioctl.
hpwc9.0.1
motion3.2.9 /
alg.h
motion3.2.9 /
conf.c
motion3.2.9 /
pwcioctl.
hpwc8.0
motion3.2.9 /
CODE_STANDARD
motion3.2.9 /
README.MacOSX
motion3.2.9 /
thread2.conf
motion3.2.9 /
motion.initFreeBSD.
sh.in
motion3.2.9 /
README
motion3.2.9 /
netcam_wget.c
motion3.2.9 /
FAQ
motion3.2.9 /
webhttpd.h
motion3.2.9 /
webcam.h
motion3.2.9 /
motiondist.
conf
motion3.2.9 /
INSTALL
motion3.2.9 /
ffmpeg0.4.8macosx.
plaster
motion3.2.9 /
picture.c
motion3.2.9 /
event.h
motion3.2.9 /
ffmpeg.c
motion3.2.9 /
netcam_wget.h
motion3.2.9 /
draw.c
motion3.2.9 /
track.h
motion3.2.9 /
mmx.h
motion3.2.9 /
conf.h
motion3.2.9 /
motion.1
motion3.2.9 /
video2.c
motion3.2.9 /
README.axis_2100
motion3.2.9 /
netcam_ftp.h
motion3.2.9 /
KREDYTY
motion3.2.9 /
configure.in
motion3.2.9 /
thread4.conf
motion3.2.9 /
pwcioctl.
h
motion3.2.9 /
pwcioctl.
h10.0.5
motion3.2.9 /
video_common.c
motion3.2.9 /
motion.h
motion3.2.9 /
netcam_ftp.c
motion3.2.9 /
rotate.c
motion3.2.9 /
netcam.c
motion3.2.9 /
video_freebsd.h
motion3.2.9 /
netcam_jpeg.c
motion3.2.9 /
README.FreeBSD
motion3.2.9 /
Makefile.in
motion3.2.9 /
video.h
motion3.2.9 /
event.c
motion3.2.9 /
ffmpeg.h
motion3.2.9 /
video.c
motion3.2.9 /
motion.c
motion3.2.9 /
motion.initRH.
w
motion3.2.9 /
Rejestr zmian
motion3.2.9 /
webhttpd.c
motion3.2.9 /
COPYING
motion3.2.9 /
webcam.c
motion3.2.9 /
thread1.conf
motion3.2.9 /
video_freebsd.c
motion3.2.9 /
alg.c
motion3.2.9 /
thread3.conf
motion3.2.9 /
motion_guide.html
motion3.2.9 /
motion.initDebian.
w
motion3.2.9 /
track.c
motion3.2.9 /
skonfigurować
motion3.2.9 /
motion.spec
motion3.2.9 /
netcam.h
Desktop $ ln y
motion3.2.9
ruchu
Desktop $ cd ruchu
desktop / projekt $. / configure
checking for Darwin ...nie
checking for * BSD ...nie
checking for gcc ...gcc
checking for C compiler default output file name ...a.out
sprawdzania, czy prace kompilatora C ...tak
sprawdzenia, czy jesteśmy cross kompilacji ...nie
checking for suffix wykonywalnych ...
checking for suffix plików obiekt ...o
sprawdzenia, czy używamy kompilatora GNU C ...tak
sprawdzenia, czy gcc akceptuje g. ..
tak
checking for gcc option zaakceptować ISO C89 ...Brak potrzeby
sprawdzanie pthread_create w lpthread ...
tak
sprawdzanie libjpegmmx ...
omijając
sprawdzanie jpeg_set_defaults w ljpeg ...
nie
Nie masz zainstalowanego libjpeg
sprawdzenia, jak uruchomić preprocesor C ...gcc E
checking for grep, który obsługuje długich kolejkach i e. ..
/ bin / grep
checking for egrep .../ bin / grep E
checking for ANSI C header files ...tak
checking for sys / types.h ...tak
checking for sys / stat.h ...tak
checking for stdlib.h ...tak
checking for string.h ...tak
checking for memory.h ...tak
checking for strings.h ...tak
checking for inttypes.h ...tak
checking for stdint.h ...tak
checking for unistd.h ...tak
kontroli mjpegtools / jpegutils.h użyteczność ...nie
kontroli mjpegtools / jpegutils.h obecności ...nie
sprawdzanie mjpegtools / jpegutils.h ...nie
kontroli mjpegtools / mjpeg_types.h użyteczność ...nie
kontroli mjpegtools / mjpeg_types.h obecności ...nie
sprawdzanie mjpegtools / mjpeg_types.h ...nie
mjpegtools kontroli ...nie
checking for ffmpeg autodetecting ...Nie znaleziono
* Libavcodec.a lub libavcodec.so lub *
* Libavformat.a lub libavformat.so nie znaleziono: *
* ALL FEATURES FFMPEG niepełnosprawnych *
* Proszę przeczytać Projekt Przewodnik o pomoc: *
* Http://motion.sourceforge.net *
checking mysql wsparcie ...badania
kontroli autodect mysql nagłówki ...Nie znaleziono
Nieprawidłowy MySQL katalogu
nie może znaleźć mysql.h.
checking for PostgreSQL ...Nie możesz znaleźć libpqfe.
h.Należy podać ścieżkę instalacji PostgreSQL
checking for ANSI C header files ...(cached) yes
checking stdio.h usability ...tak
checking stdio.h obecności ...tak
checking for stdio.h ...tak
checking for unistd.h ...(cached) yes
kontroli fcntl.h użyteczność ...tak
kontroli fcntl.h obecności ...tak
sprawdzanie fcntl.h ...tak
kontroli time.h użyteczność ...tak
kontroli time.h obecności ...tak
sprawdzanie time.h. ..tak
kontroli signal.h użyteczność ...tak
kontroli signal.h obecności ...tak
sprawdzanie signal.h ...tak
checking sys / ioctl.h użyteczność ...tak
checking sys / ioctl.h obecności ...tak
checking for sys / ioctl.h ...tak
checking sys / mman.h użyteczność ...tak
checking sys / mman.h obecności ...tak
checking for sys / mman.h ...tak
checking linux / videodev.h użyteczność ...tak
checking linux / videodev.h obecności ...tak
checking for Linux / videodev.h ...tak
checking sys / param.h użyteczność ...tak
checking sys / param.h obecności ...tak
checking for sys / param.h ...tak
checking for struct v4l2_buffer ...tak
sprawdzenie pomoc V42L ...tak
checking for short int ...tak
sprawdzenie rozmiaru short int ...2
checking for int ...tak
sprawdzania wielkości int ...4
checking for ANSI Cconforming
const ...tak
Detected CPU: Intel (R) Core (TM) 2 Duo CPU E6550@2.33GHz
Optymalizacja procesora: march =
i686
sprawdzanie bswap instrukcji ...tak
configure: creating. / config.status
config.status: creating motion.initFreeBSD.
sh
config.status: creating motion.initDebian
config.status: creating motion.initRH
config.status: creating motion.spec
config.status: creating Makefile
* * Stan Konfiguracja
OS: Linux
Wsparcie pthread: Tak
jpeg Support: No
** Fatal Error MUSISZ MIEĆ jpeg Support ***
MJPEG Support: No
V4L włączone: Tak
V4l2 ekranu: Tak
Wsparcie FFmpeg: Brak
Obsługą MySQL: Nie
Wsparcie PostgreSQL: Brak
CFLAGS: g
O2
DMOTION_
V4l2 DTYPE_
32BIT = "int" DHAVE_
Marzec BSWAP =
i686
LIBS: LM
lpthread
LDFLAGS:
Install prefix: / usr / local
desktop / projekt $ make clean
Zapraszamy do procedury instalacji Motion, demon wykrywania ruchu!Jeśli pojawi się
komunikatów o błędach w trakcie tej procedury, należy zgłosić je do listy.Projekt Przewodnik zawiera wszystkie informacje powinny chcesz poznać Projekt i prowadzenie.
Run "make updateguide", aby pobrać najnowszą wersję programu Motion Guide.
Wersja: 3.2.9
Platforma: Windows (jeśli jest to nieprawidłowe, przeczytaj README.FreeBSD)
Usuwanie oraz skompilowane pliki binarne ...
Wersja: 3.2.9
Zależności prądotwórcze, proszę czekać ...
In file included from motion.h: 247,
z motion.c: 10:
netcam.h: 18:21: error: jpeglib.h: Nie ma takiego pliku ani katalogu
z conf.c: 26:
z draw.c: 13:
z video.c: 12:
z video2.c: 68:
z video_common.c: 12:
z netcam.c: 40:
z netcam_ftp.c: 11:
z netcam_jpeg.c: 15:
netcam_jpeg.c: 21:20: error: jerror.h: Nie ma takiego pliku ani katalogu
z netcam_wget.c: 26:
z track.c: 11:
z alg.c: 9:
z event.c: 13:
z picture.h: 13,
z picture.c: 11:
picture.c: 15:20: error: jerror.h: Nie ma takiego pliku ani katalogu
z rotate.h: 14,
z rotate.c: 32:
z webhttpd.c: 13:
z picture.h: 13,
z webcam.c: 21:
make: *** [. zależeć] Błąd 1
desktop / projekt $ make install
Instalacja plików ...
mkdir
p
/ usr / local / bin
mkdir p
/ usr/local/share/man/man1
mkdir: nie można utworzyć katalogu `/ usr/local/share/man/man1 ': Permission denied
make: *** [install] Błąd 1
desktop / projekt $
Hi shiv_emf ...I już wyboru mojej biblioteki pakietu, i tylko libjpeg62 ..I również potrzebę jpeg62.dev ..Ale nie w moim pakiety.U jakiś pomysł gdzie ją dostać?Jestem początkujący ...
sudo apt-get install libjpegdev
Hasło:
Czytanie list pakietów ...Zrobione
Budowanie drzewa zależności
Odczyt informacji o stanie ...Zrobione
Inicjowanie stanowi pakiet ...Zrobione
Budowanie bazy etykiet ...Zrobione
Nie udało się odnaleźć pakietu, którego nazwa lub opis dopasowane "libjpegdev"
Nr pakiety zostaną zainstalowane, uaktualnione lub usunięte.
0 aktualizowanych, 0 nowo zainstalowanych, 0 do usunięcia i 0 nie aktualizowanych.
Need to get 0B archiwów.Po rozpakowaniu 0B will be used.
libjpeg aptitude search
I libjpeg62
Independent JPEG Group runtime JPEG
sudo apt-get install libjpeg62
Pisanie rozszerzonych informacji o stanie ...Zrobione
